Dolly Towing a 200
Madison, MS
Can I tow a 200 with front tires on a HD 6500 lb dolly?
Curb weight is 5,690 lbs.
Remove the rear driveshaft?
Is there a mechanical reason not to do this?
Thanks
If you pull the rear driveshaft you can dolly tow with the front wheels on the trailer.
If you attempt to dolly tow without pulling the driveshaft you will spin up the gears in the transfer case.
The problem with that is the transfer case oil pump is driven off the input shaft of the transfer case.
Basically the oil pump wont be turning and you will burn up the transfer case.
