Does toyota sell the u-joints for the CV joints?
USA
Does toyota sell the u-joints for the CV joints, or a kit that contains them?
If so what is the part called?
I can find the CV boot kit but not the joints.
What would you be looking to replace? Our CVs aren’t like driveshafts where all of the wear parts can be exchanged. Even if you put a new star and balls into the outer joint you’d still be using the old wear surfaces in the cup. Same for the inner.
If replacing wear parts the only thing you’d be keeping would be the actual axle shaft.
I had a clicking sound on turns like the CV clicking when they are going out, so I was wondering if they were easily rebuild able like the dodge and chevy ones.
Further diagnostics on my part found the OEM front wheel was making the clicking sound.
Swap the wheel and it went away.
What was on the wheel was making the clicking sound? Did you swap it with another wheel on the vehicle?
I do not know what was causing the clicking. It only occurred when turning and going up a small grade. Sounded exactly like a CV joint.
I have the same wheels on my Camping Trailer so I swapped them. No clicking on my camper and no clicking on my LC200 after the swap.
I have spacers and then the wheel on the LC200 and the camper has adapters. I did re-torque everything.
