Does this engage 4x4 ?
Lahore
Its my first 4x4 and I am learning its functions.
The engine is idling and gear position is at “P”
There is a diff lock knob. When I push it and twist towards right, then “one red indication turns on at cluster” (FR). And when I further shift that knob to further right position, then “Two red indications of 4x4” turns on (FR-RR). Just like you can see in photos.
The 4x4 lever is at “H” position where it stay normally all the time.
Now, when I will shift the gear into “D” then these two red indications keeps blinking.
Does it means that 4x4 is engaged ?
when you are in L central differential light will turn on
your rig is constant 4X4 rig if it was not moded
put in drive you can drive in low gear
whin you whant to go back to high then go from P or D to N ant push the short handle forward to H
the central dif light will turn off
That i know sir. :)
but as the short handle has three positions H N & L. And it stays at H all the times with normal everyday driving D.
Now during the normal driving D, what will happen if i push the knob & twist to 2nd right position (FR-RR) ?
Will that engage 4x4 without touching short handle ?
frankly i did it and these red indicators kept blinking all the times while i do not feel any difference in vehicle's normal running.
Welcome to MUD.
WIth the 4WD function in a Land Cruiser, you are in all wheel drive all the time. SHort stick in H makes one wheel in the front and one wheel in the back have traction. Short stick in L locks the center differential. The switch on the dash gives you the ability to have traction in all wheels. RR makes both rear wheels turn. FR-RR causes all wheels to turn.
Do not turn on the dash switches while you are on pavement/hard surface.
Blinking lights mean the axle is not locked.
That i know sir. :)
as long as lights blink the axles lockers didnot engage and its good DONT DO THAT!!!! you will break something this lockers should be used only when rig in full stop and in N and driving on dirt road for short periods of time as needed
If your lights constantly blink, try this- like others have said “ONLY DO THIS IN SAND, DEEP SNOW OR MUD” 1) put tranny in N 2) move transfer case to L (short stick), 3) turn dial until both lights are on 4) begin driving..... if lights keep blinking, slowly begin driving in a “figure 8” pattern, drive it forward, maybe reverse for a couple feet, then forward some more. This SHOULD engage lockers! If not the actuators on the diffs probably need some tweaking. REMEMBER- DO ALL THIS OFF ROAD! Good luck!
Can some one educate me on this? Why is it bad/dangerous to engage lockers on pavement if you are just testing engagement AND keeping things in a straight line and at low speed? Seems to me that if you aren’t turning, then the fact that all wheels have high grip is no big deal. I pick up my 80 from the shop soon and want to verify the lockers engage, how to best do this?
Best way to check them? Move off the road, unto the shoulder in the grass or gravel, and engage.
Pavement is bad because if you slip ANY you could be replacing things again! If you want to risk it, it’s your $$$. We are just trying to teach you the CORRECT procedures. Good luck and enjoy!
There are a few folks who have broken birfield joints in the front axle from locking the differentials with the dial, and driving in a tight circle on pavement.
To test that they are functioning properly, engage them on soft ground, loose gravel or wet grass is ok, and see that the blinking lights stop to show that the lockers have fully engaged.
The lockers are more prone to needing service than the transfer case engaging in 4WD.
To the OP, do you understand the difference between a part time (2WD/4WD) vehicle and a full time AWD/4WD system and how it works?
