Does Steering Box leak require rebuild?
My 97 fzj80 is leaking from beneath the nut on the top of the steering box. Under load, it streams out!
Does this require a rebuild, or is there a seal there that can be replaced, or....? I read that tightening the nut helps reduce play, but is it advisable to tighten it to help reduce the leak?
Thank you!
There is a washer under the nut with a built in o-ring. You need a new one, not a rebuild. Be very careful with the sector shaft pre-load when it goes back together. There are some good youtube videos that show how to set that pre-load. If you set it too tight, it will bind and wear very quickly.
Yep, just unscrew the locknut all the way, then pry up the little washer (should have a rubber seal bonded to the inner diameter) and replace. The part is included in the steering gear reseal kits but I suspect someone will know the official part number.
Thank you both!
If anybody knows the part number, please post it up.
