Just looking for a general pdf with basic maintenance torque specs if anyone has made one. Everything from differentials to PCV valve
Front Differential Drain Plug:I don't know if there's a PDF but I can help you find the common ones if we make a list.
| 2018 LX 570 | ||
| Part Tightened | N*m | ft.*lbf |
| PCV valve x Separator case | 5 | 44 in.*lbf |
| Spark plug x Cylinder head | 21 | 15 |
| Ignition coil x Cylinder head cover | 10 | 7 |
| Oil pan drain plug x No. 2 oil pan | 40 | 30 |
| Oil filter cap x Oil filter bracket | 25 | 18 |
| Oil filter drain plug x Oil filter cap | 13 | 9 |
| Transmission oil pan tube x Automatic transmission assembly | 0.8 | 7 in.*lbf |
| Transmission case cover | 13 | 9 |
| Overflow plug x Automatic transmission assembly | 16 | 12 |
| Refill plug x Automatic transmission assembly | 39 | 29 |
| Front Differential Drain plug | 39 | 29 |
| Front Differential Filler plug | 39 | 29 |
| Rear Drain plug | 49 | 36 |
| Rear Filler plug | 49 | 36 |
| Wheel Axle hub nut | 131 | 97 |
| Transfer Case Filler plug | 37 | 27 |
| Transfer dynamic damper x Transfer assembly | 12 | 9 |
| Transfer heat insulator x Transfer assembly | 30 | 22 |
| Lower transfer case protector x Transfer assembly | 14 | 10 |
| Transfer Case Drain plug | 37 | 27 |
^^^ This is the Way.I would strongly suggest getting a copy of the FSM.
Hello gentlemen,
I am looking to download the factory service manual for 200 series. All links in the forum are "non-working". Please let me know where I can download the FSM,
thank you so much in advance,
Rafi Litmanovitz
- Litmanovitz
- Forum: 200-Series Cruisers
Nerds.
I peak at your spreadsheet here and there to find stuff lolAs a result of encouragement from a couple people I'm putting a thread together to talk about how we track maintenance on our rigs. The idea of a cloud-accessed spreadsheet was a game changer for me, personally, putting all of the information I need to plan and do work in one spot, accessible from any device I happen to be using. Over time this evolved to include.. everything. Part numbers, how-tos, torque values, fluid specs & capacities, TPMS IDs...
So here is what I have to track and plan maintenance, and I was hoping others could contribute their methods and ideas to maybe make mine...
- bloc
