Does anyone actually go 4 wheeling on their stock 20s?
Yes, a good set of ATs on 20s are absolutely capable off-road. I've done technical crawling and also high speed washes. Air'd down to 20psi (or less) feels great on this stuff. And AHC does its part to keep body motions in complete control. Plenty of sidewall IMO, when paired with a 33" or larger tire.
I personally went with wide 305/55/20s (33.2"x) for multiple reasons. Firstly, I kept the 20's as I tow. This with Load E tires and 42 PSI keeps things stable for freeway towing. Yet it's plenty of sidewall for off-road when aired down. The wider tire and sidewall works well to keep rocks and curbs away from the rim lip. As an aggressive on-road driver, it also makes up for traction losses with AT tread having more voids, taller tread blocks, and AT compounds.
Yes, it's necessary to run a spacer for the wider tires. 1" all around in my case, giving a 2" wider track. But it's a win-win in my book. With the tire size giving a slight lift and increased center of gravity, the wider track regains some of the lateral stability. It also fixes the scrub radius geometry that comes with using larger diameter tires. Pushing the tires out, also means that because it's now flush with the body lines, that sliding sideways when on off-camber trails, that the tires work to keep the body off the terrain.
I've been really enjoying the setup all around, under tow, off-road, on-road braking/cornering, and rain/snow performance. Credit also goes to the Falken AT3Ws as they've more than exceeded my expectations.
I have the 285/55/20’s without spacers and I have no rubbing on a atock LX. I agree with Teckis on most of his post but I don’t do rocks.
Much appreciated. Just checked that size out. We have a set of winter wheels/tires, so we are interested in either a summer tire or a touring tire or smooth all season. Thanks for the info. The database had a bunch of sizes, but most of the members with larger tires tended to have a modified suspension or wheel well.
I did have to remove the front mudflaps, and the KO2s run slightly smaller than other brands in the same 275/65/20 size. Just keep that in mind if you decide to go that big - they're definitely the absolute biggest you can go on a stock truck IMO.
Yeah, those are long gone. You get a lot of clearance to the rear of the wheel (more than you need) once you remove the running boards.
I also got rid of the aero flaps and trimmed the huge rear mudflaps flush with the bumper (which are unnecessary, and most SUVs and pickups don't have them). I view them and the running boards as low hanging plastic POSs.
So how often do you change your AHC fluid, based on your more aggressive use?
I meant that I air down the tires to 20psi.
I'lI typically set AHC to full soft in off-road running.
OIC. I have changed it on my 100-series. It's on my todo list for the 200-series which I haven't tackled yet. Including all fluid maintenance of diffs, transfer case, tranny, and coolant.
Chiming in... running 275/60/20 Toyo AT on my F150. Like 41lbs. Outstanding tire worth looking at because it’s so light.
Specifically got 20 inch wheels so I could try them out.
Will never run an E tire on a half ton again. Really hampered my Tundra, not worth it.
These are great pics! What year is your LX?
How do you like the wildpeaks? @koretex
LOVING them so far. Great price, great size, great looks. Most importantly of course is performance. Noise is barely more than the street Michelins that were on her. I've only got about 800 miles on them so far, but dry has been great. Rain, whether just started, drizzling, pouring, whatever, it likes the water isnt even there. Gravel service roads, muddy washed out roads has been great. Even the flooded abandoned railroad tunnel I posted a pic of above was no issue for them. VERY happy so far.
