Dodge 318
I see that pictures of my cruiser are a must. I will have to take some and post them shortly. I have a 1970 fj40 with the original inline 6. Odometer is broke so I don't know the mileage. For the most part it is still stock except for the Aussie lockers, front and rear which I had installed and the shackle lift the previous owner installed. I am excited because I have always wanted a cruiser and I lucked upon this one at the back of a used car lot. I now have it.
The engine over the last month has started burning oil profusely and is losing power with every crank. Unfortunately, my mechanical ability is fledgling and I will be using a mechanic often until I know better what I am doing. My first jump will be a new engine. I have a running 1981 Dodge 318 available. Anyone done a conversion?
Not with a Dodge 318 in an FJ40.
I did do a 318 conversion in my 1951 Dodge M37 army truck, just to keep it all Dodge. I have a early 318LA (wedge, not poly) that has the steel crank. That was available only for a short time in heavy duty pickups.
In my opinion, the 318LA is one of the most reliable and long lasting of the cast iron smallblocks. They just run forever.
Seems strange. Do a compression check.
I wouldn't recommend doing a non-standard conversion. You'll end up getting stuck on the tidbits and having your truck sit in the garage for months or years. Rebuild the 6 or trade that 318 for a chevy.
Thanks for the tip on the compression. I will check that out. That would sure be cheaper than an engine swap. I didn't consider a rebuild since it was burning oil. I suppose it could simply be the rings. I think I may pursue this route first. The last thing I want is lots of custom fabrication from doing something terribly unusual.
I have read a number of the threads discussing conversions opposed to rebuilds. I suppose the power issue can be resolved with gearing. I plan to run 38.5 inch swampers after a SOA and 3" lift. My concern was driving to and from the trail, but if I can gear it to maintain 55mph or 60mph on the interstate then I would prefer to stick with the toyota motor.
i agree with fast eddy, i have owned power wagons in the past, you can't break them with a hammer. but trying to do a cruiser mopar mutant will be an ugly experience. trade the 318 for a chevy 350, everybody and their dog puts them in everything from volkswagons to jeeps,.
It might sound hoakie, but try a quart of "power punch". When I first got mine running this summer it went thorugh a little oil, but not a lot. Then when hnting season rolled around, it went through almost 5 quarts in two days. I even bought a spare f engine off a guy 'cause I figured it was inevitable. I swung by my dads on the way back and he talked me into putting a quart in and it has not burned a drop since. Runs smoother and seat of the pants feels stronger. I use to run it in my semi and forgot how good it was. Must have freed up a stuck ring or something.
