Dobinson spring spacer ripped (1 Viewer)
lumbee1
Native American
Holly Springs, NC
My 3 year old @DobinsonsUSA 30mm rear spring spacer has ripped. This was used to correct the common driver's side lean on the 80 series. I was in the process of installing a @Delta VS panhard bracket and had to remove the spring to get the control arm bolt out. When the spring was removed the spring spacer fell off of the spring retainer.
Any recommendations for another spring spacer?
Are you sure you have the springs on the right side ? 30mm is more then a inch, that’s a lot of correction. I have the same driver side lean but it’s less then a 1/4” or around 7mm
I would try switching the spring side to side. most spacers for lean correction Are in the 10 to 15mm range.
When I first installed the springs, I tried them both ways. The lean was about the same. With a 30mm on one side, the truck was level.
The driver side springs should be taller. So when you moved then around you should have seen a difference. If it was the same I don’t know 🤷‍♂️
