Thanks!! Sweet setup btw. So its not quite flush as the drawers are shorter in height compared to the 2nd row seats?I have the Dobs drawers and all you need to do is when you lay the second row seat back down forward, just pull the lever on the side of the seat to release the seat bottom and place either a board or something underneath it that will level the seat out. Then you can lay your inflatable mattress across the top of the drawers and the seat back. Depending on the size of you mattress you'll need to slide your driver/passenger seats forward for extra space. Lastly I found too that if you take of the rear passenger head rest off then spin it around and reinstall it, it will work as a pillow or give you a little extra support for a pillow.
Hopefully I explained that clearly for you.
It just looks like a ramp towards the passenger seat in the photo because I didn't prop up the back seat. Once you put a 2x4 or something under the seat it will level out pretty good.Thanks!! Sweet setup btw. So its not quite flush as the drawers are shorter in height compared to the 2nd row seats?
Ahh gotcha I think I understand.. So you put a 2x4 at an angle with the seat so that it becomes level with the drawers? Do you happen to have a photo of the seats folded but without your mattress in the way?It just looks like a ramp towards the passenger seat in the photo because I didn't prop up the back seat. Once you put a 2x4 or something under the seat it will level out pretty good.
You just need to put a 2x4 under the seat bottom where it clips in to the anchors in the floor. No need to angle it just lay flat. I'll take a photo later and post up.Ahh gotcha I think I understand.. So you put a 2x4 at an angle with the seat so that it becomes level with the drawers? Do you happen to have a photo of the seats folded but without your mattress in the way?
Not sure if this helps at all. So you will have a small gap between the seat and the drawers but it's not noticeable at least to me. Like I said just put something under the seat bottom once you release it from the holders. Anything will work to level it out.Ahh gotcha I think I understand.. So you put a 2x4 at an angle with the seat so that it becomes level with the drawers? Do you happen to have a photo of the seats folded but without your mattress in the way?
Awesome thank you!!!Not sure if this helps at all. So you will have a small gap between the seat and the drawers but it's not noticeable at least to me. Like I said just put something under the seat bottom once you release it from the holders. Anything will work to level it out.
Any drawer system works as a sleeping platform....all roughly same dimensions....I used solvefunction "block" to level the folded seats. My drawer is the Landshark outfitter.bumping this thread for feedback on the Dobinsons drawers!
