Do my rock sliders need more gussets
Looks great and has inspired me to build my own. I like the round tubing look that your has off of the square runner. If you do not mind sharing I was wonder what angle the bends were, what angle up the ends were cut and last how far the tube is from the square runner. It looks to be a very nice choice in dementions. If you do not want to let forth your design brilliance I do understand. Thanks for posting your build, it was great.
I simply set the rectangular tubing on Jack stands and shimmed under rect tubing to get the right spacing which was about an inch from the body. And i made multiple cuts in the square tubing that mounted to the frame until they lined up. The first side takes the longest. The second side is much easier. I did a second pair for a friend and we used round tubing for supports to the frame and square tubing. much lighter. but needs more spacing between square tube and body because it is not as stiff.
angle of the round tube is around 35 degrees if my memory serves me right.
Hope this helps
