Do I need this radiator hose?
i just finished the oil pump cover gasket and crank seal job. Really wasn't that bad. I had to bump the starter about 7 times to get the crank bolt loose and needed to drill out one of the cover screws with a grabbits bit. Prob took 4 hrs total.
While I was putting the small coolant hose that runs from under the distributor straight forward to a small nipple on the top of the radiator, the nipple broke off! I put a screw in the hole in the radiator and crimped the hose over.
My question is, how important is this hose? Can I live without it? It looks like I'll need to replace the radiator if I want to fix this issue and I don't want to do that right now. Can I drive for a while without this connection in place?
Yep got replace the rad. I did the same thing, very frustrating. At least it gives you a chance to do some PM on your cooling system
OK. I just ordered a new radiator. I need to drive this week. Is that a terrible idea or can I get by for a few days?
You're not alone! You'll be fine, I recently had to do the same thing (although my oil pump seal job went much smoother than yours:)) and drove around for a week while the new radiator got shipped. Just keep an eye for leaks until you put a new radiator in there.
The purpose of that hose is to let any air trapped in the system that is why it is on top of everything else. You can drive with no hose. Just watch for air plugs in the cooling system.
I'm not too heart broken. The coolant was old and needed to be replaced and I don't know how old the radiator is, so it's money and time well spent. I'll just keep an eye on the temp gauge while I drive this week.
After removing the fan, shroud and a few hoses to do the oil pump gasket, I'm much more confident about doing a radiator job! This is how we learn!
Thanks again guys.
Been there had the same exact thing happen during my oil pump gasket repair... I JB welded the nipple hoping it would last... And took off to Mexico for a week... Sure enough lost a lot of coolant since the JB weld did not hold.... so I looked for a rad shop in a no mame dinky town in Sonora...hoping they could weld tap or somehow trail fix it to get me home.... 2 hours and $30 later they had rebuilt my rad with a new top plastic piece, flushed the cooling system, replaced my PHH and my heater valve... ( Yes I had the diverter valve and Silicone PHH kit in my just in case parts I carry in the cruiser) .. apparently this rad can be totally rebuilt ( im Mexico) where they sell all the individual parts !!!! I love mechanics in Mexico.. had I been in the states I would have had to shell out literally 10x the $$ just for parts and would have still had to imstall it myself ! $30 for a rad rebuild heater valve and PHH .... really... they even gave me the shamefull look of "am I charging you too much? " When I asked how much?... I happily paid them the $30 and bought a 12 pack of tecate for them.. then drank a couple with them
Thanks again guys.
Once you've removed the radiator once, you'll curse yourself for not having done it prior to removing your oil pump.
Lots more room without that big fragile turd sitting there.
A "while you are in there" todo is to replace both of the transmission rubber lines under the rad. Shortly after I overhauled my cooling system, I had one of these hoses crack which caused a severe leak. It was a real pain to reinstall those hoses with tranny fluid onto the metal line, minimal clearance to work with. It would have been much easier if the rad was removed. You can get the hoses cut at your local auto store, it's pretty cheap for them. Once you remove the rad, you will see what I am referring to. Just remove them or measure each one and go to the store with the lengths for them to cut.
