I have a 97 LC running 315/75/16 sized tires. I just sold my old bfg at tires and am looking at some cooper discoverer stt tires but not sure if I need to e rated which cost more.
No, you do NOT need E-Rated tires. Read the load ratings on the tires you are looking to buy.
If you have a stock rig, it is about 5000 LB. That equals 1250 LB/ wheel.
If you have a HEAVILY loaded rig pulling a trailer (about 8000 LB +500 LB tongue weight, you will need tires rated for at least 2250 LB each (8000/4) + (500/2) for the tongue weight on the rear wheels.
So somewhere between 1250 LB/ wheel and 2250 LB/ wheel.
The higher the load rating, the higher the class. We used D rated tires on our pickups to haul FULL loads of wood or livestock and never had an issue. An 80 cannot come close to that load.
I have a set of 315 Cooper STMaxx. Load E.
I thought they would be to stiff etc.
I was running the same tire in a 35 X15 C rating.
The difference I felt with the E tire is more stability & better road manners. The thicker side wall does many things better. More puncture resistance ect...
Are they the new design STT?
Tools and many more of us around here are running the older style of Cooper STT in 37" and "D" rated. We beat the snot out of them and they hold up very well. We also inspected the first set of the new style that came in at Desert Rat. Same casing with some cosmetic changes: cute little traction cups in the lugs. Whatever?! Sidewalls have a different design that MAY allow more flex with less stress/damage to the sidewalls. Time will tell. John
