Do I need a resistor?
Utah
Replacing stop, turn, tail lights with some amazon LED surface mount ones to go along with my bumper build. Do I need to get a resistor for them to work? I doubt they have any kind of resistor in built into them. :beer:
yes
I got all my LED's from Supper bright led's.
They have just about anything you need for you vehicle and the lights have built in resistors so it is pretty much plug and play.
I used the special blinker for my Toy because the turn lights wouldn't work on all LED's
You can leave the incandescent bulb in the dash light and the blinkers will work but they flash very fast.
DOT specifies 60 to 140 flashes per minute.
What flasher did you use? I’m on my second one. My hazards work now, but still no turn signals.
There are different blade patterns so you will have to figure out which one you need but it looks like this.
My 1970 has two flashers. One for hazard and one for turn.
Make sure there are no shorts in the wiring as it doesn't take much to knock the unit off line permanently.
