dizzy swap complete. vacuum line ?
Eagle River, WI
dizzy swap complete. carb flooding & vacuum line ?
I have completed a 78 dizzy into a 77 FJ40. I've got spark. I have gas flooding into the carb. It does try to start and gets flooded out. I do need help with the vacuum lines. Are they related??
Flooding is flooding. Either the float is dead, stuck down, needle is stuck open or you've got more fuel pressure than the needle and float can handle. Chances are it's not a fuel pressure problem.
Pull the air horn off the carb, test the float in a bowl of liquid to make sure it stays afloat and take the needle out of the seat and blow out the carb inlet with some carb cleaner. S
SHould fix it right up. ;)
Mark is still right as the same principles apply. Do you have the stock Toyo mechanical fuel pump or electric?
Ed
Do you have any vacuum lines running to or from the Holley? Probably nothing more than ported vacuum for diz advance. Most likely, your float is stuck, like Mark said.
Ed
The ones on the cap are just for ventilation and have no effect on the carb. The one from carb to diz is just the vacuum advance, so neither of them have anything to do with the carb flooding.
Chances are you have a piece of crud in the needle and seat under the float.
GL
Ed
Yo guys were right. It seems the "O" ring for the seat and needle was bunched up. No more flooding gas. However, it wants to start and just won't fire. I haven't positioned the distributor yet. Where is a good place to start. Middle, all the way left or right? Thanks again
How did you reinstall the diz? Did you make sure you were at TDC on the #1 cylinder? You have to have it in the ballpark and when you do, it will start.
There is a write-up somewhere that has been posted with a step-by-step on the installation of a diz. You could be 180* out and it will try to start.
GL
Ed
That's the post, thanks, Goat.
Ed
Thanks for the link. I did get it running but very rough. May be a timing thing? I did get the #1 to tdc before I took it out. I also lined up the rotor with #4 after it was all the way down. I'll look over the Romer list next. I did put a charged battery in also.
In the Haynes manual, supplemental section for later models, it says to use the TDC line, not the timing mark ball for the 78 electronic dist. Found this after a bad start. After working out some other issues, I hope to re try it with that setting. It gets confusing some times as the reference to the timing mark I believe is the brass ball and TDC (BDC) is the line. Please correct me if I'm wrong.
