got a real simple one for ya, get 1-1/2" PVC and two caps, cut a slit all the way down, get 1/2" PVC cut to 1" longer than 1-1/2" tube with caps on and cut a slit all the way down. put tarp edge in 1/2" and roll up tight, slide into 1-1/2" tube. use a hole saw to cut a hole in each 1-1/2" cap to fit 1/2" PVC tight. glue the caps on. make a handle for one end and you have a windup canopy. at least thats how i did mine.![]()
What kind of PVC are you using that does not distort from the heat?
but i was smart and dont just have it mounted on both ends, its absolutely amazing what supporting a structure through its length can do.thread revival...
How about some pics of your DYI canopy?
