So i was sitting in the garage today, I just finished painting my grill to get rid of the lame fake chrome. I am preparing to do a tune up and replace my VSV for EGR because of my PO 401 code. The dealer did a diagnostic for free and told me it was the VSV. What was odd was my code was thrown on a "day trip" where i poured a can of BG 44K in my tank. We put on about 350 miles that day and I threw the code around mile 200. This happened about 16 months ago. The dealer did a diagnostic for free and they told me the code was a PO 401 for the EGR. I had the code pulled at auto zone and they confirmed this. I am a
guy and like a challenge. I ordered rotors, pads, plugs, spark plugs, cap, rotor cap fuel filter and VSV for EGR. So I was studying the under hood today and thought to myself I should get all the vacuum hoses replaced while I have the intake plenum off! So i took a couple hoses off and they looked pretty good and had no restriction. The last hose is the 7 inch piece that runs from the EGR valve to the intake plenum. I could not blow though it. I thought dang, that BG 44K must have blown a piece of carbon through this hose and it got stuck and built up! I finally was able to work this piece of crap out and it turns out it is some type of wire sheath, or small straw that is 1 inch when bent in half as it was and creating a complete block! We bought our truck in Dec of 2005 and it threw the code in May of 2007 and I have driven it since then because I simply didn't have time to fix.
Did my dealer try to screw me by doing this. No one else has access to my car and I do most of the work besides the oil change that time before the trip! Would this have caused my Code 401? I hope this solved the problem, I will keep you guys posted!
First picture, Port where vacuum hose plugs into intake.
second picture, hose on the nipple
third picture, Crap that was pulled from hose!
guy and like a challenge. I ordered rotors, pads, plugs, spark plugs, cap, rotor cap fuel filter and VSV for EGR. So I was studying the under hood today and thought to myself I should get all the vacuum hoses replaced while I have the intake plenum off! So i took a couple hoses off and they looked pretty good and had no restriction. The last hose is the 7 inch piece that runs from the EGR valve to the intake plenum. I could not blow though it. I thought dang, that BG 44K must have blown a piece of carbon through this hose and it got stuck and built up! I finally was able to work this piece of crap out and it turns out it is some type of wire sheath, or small straw that is 1 inch when bent in half as it was and creating a complete block! We bought our truck in Dec of 2005 and it threw the code in May of 2007 and I have driven it since then because I simply didn't have time to fix. Did my dealer try to screw me by doing this. No one else has access to my car and I do most of the work besides the oil change that time before the trip! Would this have caused my Code 401? I hope this solved the problem, I will keep you guys posted!
