Does anyone know what years Toyota chose to put the concenser inside the distributor? That's where mine lives and so puttinng in a "pointless system" seems, well, pointless or impossible.
rogersfj401969 said:Resistor is on the positive side on the coil, its ‘job’ is to bring down the voltage going to the coil so that it won’t burn out. Note some coils don’t need resistors, but some do.
Petronix says to keep the coil resistor if there is one there; this is so that you won’t burn out your coil
FLYINGLOW said:The resistor is there to step the voltage down to prevent burning the points. .
Pin_Head said:The resistor is really there to keep the coil from sinking too much current and burning up.
The points could care less whether they get 9V or 12V. Their main problem is when the points open and the high voltage jumps across the gap. The condensor on the - side of the coil helps to prevent or minimize the arcing.
You might wonder why use a coil that will burn out at the full 12V? The reason is that they start more reliably during engine cranking when the voltage drops to 6-9V. After cranking, a resister is in line with the ignition circuit dropping the voltage to 9V.
