fjwagon said:Do the same thing to the starter or you have a rusty starter.![]()
Mark W said:Actually that is a real old article and could stand some updating.
In any case, if your '79 FJ40 has the factory distributor, a little silicon grease at each end of the plug and coil wires (good fitting wires such as OEM FJ60 wires helop a LOT)... It'll run under water.
Mark...
Mark W said:The small one goes to the air cleaner assembly (via some intermediate connections in the '80 and later rigs) and the larger one goes to a port on the firwall which leads to a small air filter on the other side.
Mark...
