distributor swap.
North Pole, AK
I realize this is similar to another question on the board, but at the same time it's definitely different. I have a 1971 FJ-40 with a stock F motor and was wondering if I can upgrade distributors from the current points-style to an electric from a 1984 toyota FJ-60 with the 2F. Have any of you tried this? Mine is so worn out I can hear the slop in the shaft while it's (barely)running!
1) Yes.
2) No, didnt need to.
Get an electronic distributor.
I am running a "big cap" out of a '60 in a 2F with no problems. Do it, you will be happy.
Ed
Pinion said:
1) Yes.
??? the distributor he is asking about IS electronic.
Mark...
YES, this is a GREAT swap and well worth it, very easy to do, hardest(only because it takes the most time) is swaping the fj60 dented side cover.
go fj60 dizzy swap.......not HEI GM crap :D
One advantage on the HEI is parts are common as dirt, you can even sneak up to some ones irrigation well motor and get what you need to get back to town. I my area no one stocks caps or rotors for any toyota dizzys , not even the dealers, takes 2 days to get something, & I'm in a large city
every(both) po dunk parts store in my small town stock all the fj60 turn up stuff, dealer ALWAYS had 60 stuff in stock.....
but with HEI......you will need to visit the parts store more often.....and might keep the # to a good toyota motor rebuilder handy ;)
I was referring to the fact that he HAS a points style distributor.
He is looking for a modern electronic version.
Pertronix all the way!
Full electronics without pulling your dizzy!
No messing with the side cover.
No expensive Toyota modules or ignitors to worry about acquiring or replacing.
$5.00 Failsafe backup-you can carry a set of points in case something goes wrong!
Of course I'm biased!:grinpimp:
Best
Mark A.
