Distributor question
Western Carolina
Ok, so I have been chasing a ticking in my engine since we put the new engine in. I so far have checked the bottom end (fine) valve clearance (fine) had the timing chain, slipper and tensioner replaced, front pulley replaced checked flex plate (fine) and am running out of things to replace!! I am wondering if there might be something wrong with the distributor. I spoke with someone who works on mostly domestics that told me it wasnt out of the scope of reality for the distributor to be bent/cracked etc... Anyone had or heard of this?? Any help would be greatly appreciated. It is a '95 FZJ motor has 118k on it, compression was excellent all else seems ok.....
Have you used a mechanics stethascope to pinpoint where the ticking is coming from?
A wooden dowel also works.
Yeah, it is in the front of the motor, but is hard to pin point. I had a friend, who also happens to be a toyota mechanic, who could not pin point it, but we both agreed that it was coming from the front of the valve cover.
My '92 4runner developed a loud tick. It turned out to be the fuel pressure relief valve. It had started making noise after 160k miles.
Did you take the little bolt out of the exhaust cam gear after the timing chain and such was replaced? By way of clarification, the exhaust cam has a gear that's actually a 3 layer sandwich which a bolt must be inserted into to hold the 3 gears together before timing chain tension is released. This way, when the timing chain is put on and the bolt is removed, there is again a sprung effect across the teeth that keeps the chain quiet as it runs across them in operation. The mechanic should have known about this procedure, so the noise makes me wonder if the service bolt (name in the manual) is still on the gear and either hitting something (tick) or causing chain noise you're hearing. That part is, obviously, right at the front of the valve cover on the exhaust side.
One heavy duty diagnostic thing you could do would be to pull the valve cover without disturbing the hoses (easily done) so everything's intact except the spark plugs and valve cover and you're staring at the cams. With the spark plugs out, using the starter spins the engine and it's quite quiet so you'd likely obviously hear the ticking. It's eerily quiet and smooth without the compression sounds. If the valve cover had to come off to find out about the service bolt on the exhaust cam gear then you're there anyway.
Yeah Doug I checked the service bolt, it wasn't there, and I inserted one to make sure the gears were lined up b/c I was told by toyota that the noise may be those gears unlashed. The bolt threaded right in and I promptly removed it. When I checked the valve clearances we removed the valve cover and hit it with the starter with the EFI fuse pulled so it wouldn't start and I have the oil all over my garage ceiling to prove it....Didn't know that the 1FZ was such a high pressure system, so we didn't have time to make a diagnosis as to whether the noise was in the valvetrain or not, but it sounds as though it is farther forward than the valves which is why I was wondering if anyone had heard of any problems with the dizzy, or possibly the oil pump.......
Ok, so I put the mechanics stethoscope on the power steering vane pump and wow!!! It almost made me deaf!!! I think the vane pump may be bad, and making my noise. How easy is it to source a PS pump?
I walk upstairs and pull one off the shelf.
I'll bet yours are $$$$$.... You had a rebuild thread didn't you dan? Also what is the price on one of your axle rebuild kits? As it is about that time....
Let me know if that fixes the noise because I have a 97 FZJ80 making the same noise. I went through everything that you did but still makes the noise. I even had one of Slee's mechanic's listen to it and he said he hadn't ever heard that engine make that noise.
I hope that is it so I can fix mine.
Could you record the sound it makes? I'm just curious. ;)
