Distributor install, '97 won't start
Tallahassee
Had distributor off for a while. Markings are not visible, rookie move on my part. So I took out #1 spark plug rotating crank shaft until at tdc using a long extension in #1 valve. Crank shaft at 3 degrees also and dizzy lined up at #1 spark plug. Truck did not turn at all. Assumed I was not in compression stroke, turned it 360 degrees. Now truck turns and sputters, it wants to start but just quite won't.
Am I probably a tooth off? How do you recommend going about this? Preferably without taking off valve cover. Truck ran fine before removal.
Ahead of time thank you for any input or help. I'm using my GI Bill in college so this is just something I work on with free time and on a limited budget since getting out.
#1 cylinder at top dead center. Distributor installed with the rotor pointing at the #1 plug wire.
No fire, remove distributor and rotate the rotor 180 degrees and reinstall.
So I'm in the same situation only mine won't start.
I stupidly didn't mark the distributor when I replaced the o-rings. Also replaced crank seal and oil pump cover O-ring. Put everything back in place and there is no ignition. Tried with crank at 0-degrees and distributor rotor at #1 plug...nothing. Rotated crank pulley 360 degrees to Zero and reset distributor rotor to #1 plug and it just turns over with no ignition. Followed the same process with the crank pulley at 3-degrees BTDC.
Battery is brand new.
Didn't mess with the spark plugs on distributor cap.
Any ideas?
