Distributor Clamp with Two Bolts
San Antonio, Texas
Just bought a 6/72 FJ40 and it has the F engine number label. I searched the forum but couldn't find my answer so... why does my distributor mount point have two threaded holes while the OEM distributor clamp for this year only has one (single sided)? I found an example of a clamp on eBay (should be uploaded below) that had two holes so I don't understand why the OEM versions only have one hole. I would think it would be more secure with a two hole clamp but I can't find them online.
Thanks!
-FJ Newbie
Well, that explains it. I thought I might have the wrong clamp. I’m still trying to get the damp distributor to seat correctly...
As you’ve probably read, if you don’t fully seat the dissy the tip won’t turn the oil pump. When you think you’ve seated it you can unscrew the oil sender to see if oil is pumping. It is on the drivers side of the block just above the oil pan. Disconnect the big wire that connects coil to center of dizzy cap, then have someone crank engine over while you watch for oil to squirt from sender hole. You can squirt oil in spark plug holes for precautionary lube.
