distributor choices
Virginia Beach
I think my 23 series mallory distributor (point style) on my 76 2F might be going bad because when I check the timing the BB wont stay still. It moves 1/4 to 1/2 inch back and forth. I've been looking at electronic repalcement ideas on this forum and on suppplier web sites. My questions are: What is the + or - of having vac advance or mechanical? Man-A-Fre has both for about $375, is this a custom fit including the gear? (I know I can save money in a yard but not crazy about the modifications needed) Do I need a performance ignition just because I run a weber 38? (rebuilding that so I'll probly be back soon. First post, great site, Thanks
You need a dizzy, coil+ignitor, and pushrod cover out of any FJ60 (or 81-83 FJ40).
The distributor is sealed, ball bearing, and pickup is fully electronic.
I bought a used setup complete for $125 about 2 years ago. Not a single problem.
The distributor is vacuum advance, which when coupled with ported vacuum (easy to port a carb for it) is a definate performance improvement over the stock stuff.
I can rev my tired old 1F all day without so much as a sputter.
I would install this all day long over the $$$ DUI and especially a chevy HEI distributor with the wrong gear.
The Weber setup (according to MAF) means you should probably buy their mechanical dui. Yes, it comes with the gear already installed. the only thing extra you should buy are the new plug wires.
As someone else mentioned though, an FJ60 or later model FJ40 will do approx the same thing for you at a cheaper price.
I've had the whole spectrum, and am now with a dui, and am happy, though my pocketbook was not when I purchased it.
