disk vs drum going backward
Northern California
My drums do fine with normal driving but what I want is really good breaking when Im in a hard spot on a steep hill. I don't want to have to kill the break pedal to stay put. So would disk be better for breaking in reverse? If so wouldn't it be better to have the disk on the back if I was to only do one axle? This would be good because the rear conversion seem to be cheaper. Opinions please.
99% of your braking is in the forward direction...
If you had discs in the rear you would be constantly locking them up or have to have a proportioning valve so tight they wouldn't get used.
Do front discs, fix your rear drums, and you will be more than happy.
The shoes in a drum brake are arranged so that they are self-engergizing which means that the shoes actually move tighter to the drum when rolling forward than if you were going in reverse given the same pedal pressure. I don't think that there is an issue with disks under similar circumstances.
