I have seen people run "breather filters" on their pcv systems, but I always say thats a bad idea.
For a short period of time, lets say if your trying to diagnose something, it would be ok since you will be replacing the pcv back into the system eventually.
But if you plan to do this for a while, i wouldn't recommend you do this and heres why:
PCV was designed to reduce blowby gasses (hydrocarbons) in the crankcase by pulling them out of the crankcase and putting them back into the combustion chamber to be burned again...
Back in the old days they used to just run a rubber hose off the crankcase as a ventilation system (i'll call this your breather filter) to help "release" the blowby gasses into the atmosphere. The problem with this is that in order to remove the gasses out of the crankcase, you need vacuum. So the tube was there in hopes that if you drive along, hopefully vacuum will be created and suck the blowby out. Just to state, the problem with this is that gasses can enter the crankcase or be released from the crankcase depending on the conditions
For those of you with disels, a similar system to the draft tube is used on most diesel engines, since diesel engines do not create vacuum
PCV uses vacuum from the intake manifold to reintroduce the blowby in the crankcase, into the combustion chamber. By using manifold vacuum, you no longer have to "hope" that the gasses pulled out of the crankcase. PCV system consist of two things, breather tube, and pcv valve. Basically, the breather tube is what introduces "fesh air" into the crankcase, pcv valve reintroduces it into the combustion chamber by using vacuum. When vacuum is low, the pcv valve will not allow gasses to escape, this is when the breather tube "acts as a pcv valve" and allows the air to go back into the combustion chamber from the crankcase. If in any case the pressure in the intake manifold becomes high (such as in a pop back) the pcv valve will close not allow that to get into the engine.
Just so you know, this:
- Helps keep the engine clean by eliminating acids that are formed from stagnant air
- Reduces sludge by removing moisture from the crankcase
- Reduces oil leaks from excesive crankcase pressure
Hope this clears things up!
