Disc Brake conversion question
F.E Warren AFB, Wyoming
hi all,
I recently installed front disc brakes on my 1975 FJ40 and was wondering what I need to do with the MC. I seem to be reading conflicting info. Here is my set up:
2/1975
Stock 2 reservoir MC
Stock booster
Rear drums
FJ60/mini front disc brake parts
Here is what I "think" I need to do. Remove the residual valve on the front and install an adjustable proportional valve to the rear.
Thanks!
Try just removing the residual valve from the front circuit . The rears should be okay as nothing else has changed . Adjustable proportioning valves are for when you add rear disks . If you end up changing the master , get one for a 60 series as they had the setup you now have from factory .
Ok got it. Definitely remove residual valve from the front circuit.
I was under the impression I needed a rear proportional valve for the rear drums as well.
I sort of ran into the same discrepancy when I converted mine to front discs. I ended up converting to 4-wheel discs in the long run, so the problem took care of itself!
1. DEFINITELY remove the residual valve in the front circuit of your master cylinder. This is absolutely correct.
2. There seem to be 2 schools of thought about the proportioning valve:
School A: Says these trucks, even when they HAD front discs/rear drums early on (1976/77) didn't have a proportioning valve in the rear. Therefore, you don't need one when you convert to front discs, as this is essentially switching over to the same setup as a 76/77 FJ40.
School B: Somewhere along the line in late-model FJ40's and FJ60's running front-disc, rear drum setups, Toyota DID add a proportioning valve. For example, the FJ60 your front brakes came from actually ran a proportioning valve to the rear brakes, which I believe are the same drums used on a FJ40. Therefore, these folks point out the maybe Toyota added this for a reason, and you should too...
My suggestion - pull the front residual valve, bolt everything back up, ensure everything is working, then find some place with loose dirt/gravel where you can safely slam the brakes. If your rear brakes lock up before the front ones, or the back end tries to come around under heavy braking - you need a proportioning valve!
Worst case scenario - you have to bleed your brakes twice.
My belief is that you will still need an aftermarket 2 lb. residual valve installed into the line that goes to front disc brakes, which will keep the front pads up to the rotors- - - school me if I'm wrong.
Probably couldn't hurt...but I'm running no residual valves front and rear (4 wheel discs) and the truck stops great.
I am planning to run the lines on my '69 for the same conversion. I'm running mine using the method illustrated in the diagram below. Note: 2psi residual valve for disc, 10psi for residual for drum.
Hi all,
I converted my '74 FJ40 to front discs ~13 years ago. Removed the residual valve in the front circuit of the drum brake master cylinder. Did not fit a proportioning valve to the rear brake circuit. No issues, worked great for ~6 years (then I upgraded to rear discs with the proportioning valve and and a 4wd mini-truck master cylinder.)
Regards,
Alan
I would not remove anything until I tested what I have. Test your setup first and the next action will be based on your results.
Going thru the same thing in my head up grading my fj 62 I bought a conversion kit for rear disk and going to a 80 series boster/master . I lost track of my proportioning valve along time ago and need to know what's best to make this work . I'm thinking simple adjustable lockout on the rear line underneath the hood any thoughts from vets of this would b appreciated
