Disc Brake Conversion Question
Charleston, SC
Newby here...
I am in the midst of the disc conversion and am running into an issue with removing the hub housing. It looks like there is a C Clip retaining, but it isn't a C Clip(i've put a 90 degree pick behind it and it won't move).
I removed the small hex bolts also.
Any and all ideas would be appreciated.
Remove or loosen the set screws with an allen wrench to unlock the spanner nut, then loosen the round spanner nut. Behind that you'll find a washer then another nut to remove. Then you can remove the hub.
Thanks! I had already removed the set screws, but couldn't get the nut moving. Thank you for letting me know it is a Spanner nut. Googled how to remove that without a special tool and it came right off!
