Before you tell how I am like the four millionth person asking questions about wiring a new alternator, let me tell you I have been reading threads for 6 days, and can't seem to find exactly what I need.
Here is the scenario: New 12Si alternator, new pulley, new mounting bracket. All is good there. Wiring the keyed 12 volt source with the original thick white wire that runs to the AM part of the ignition switch. 4 gauge wire from battery to battery lug on alternator.
The question is in the regulator. Mine does not have a harness like some pictured on here. So I was wondering the proper way to disarm it. I have a white with black going from the regulator towards the alt.. A white with green going towards the alt.. A white with red going through the firewall, and white with green going through the firewall.
So do I just connect some of these wires and remove the regulator, or do I need to run some of the wires back to another source? I believe the white with red goes to the flasher unit, and the white with black is a ground. What do I do with the white with green and should the white with red go to a 12 volt source?
Thanks for any help
Jeremy
Thanks for any help
Jeremy
