Dim E-Brake light after tires installed
Just past the middle of nowhere in South Texas
New tires installed today. Driving away from shop noticed E brake light was on but very dim. Stopped and pulled up on E brake and the light got brighter. Disengaged E brake and light went back to dim.
Brake fluid full. Unplugged sensor and plugged back in. No change.
Certain it was not on before tires installed. 2.5 inch lift and moved upto 33 inch tires.
Is the little extra lift with talller tires possibly pulling on the E brake? Could this be just an adjustment issue?
Thanks is advance.
Did the light go out when you unplugged the sensor in the cap?
Likely a bad float switch in the cap. Very very common.
Yes, goes out when unplugged and comes back on when plugged back in. Just strange it happened immediately when the tires were changed. I did notice the fluid level in the brake reservoir is high. I suspect when new front pads were installed (recently when lift was put on) the level increased and tech did not notice fluid level was above the full line. When the tires were installed the shop used a floor jack and jacked each front side up individualy. Could the high fluid level coupled with the vehicle lifted on one side caused the float to malfunction? Maybe a stretch....
Naaaa. These things just fail over time. You didn't give details on your truck, but that float switch is anywhere from 23 to 29 years old. It really doesn't owe you anything.
Depending on the year, the Cruise control will not allow you to set a speed if that brake light is on.
Part number 84460-60020 is the cap, but it is now discontinued. I would look for a good used one in the classifieds or one of the vendors on this forum.
Thanks @jonheld Sorry, the 80 is a 95 and just turned 260k. This is my second time around owning this particular 80. Sold it in 2012 and purchased it back in October of last year. During my first ownership, I replaced the master cylinder and reservoir/cap, but can’t remember exact timing. It was done by a Toyota dealer, but have to figure it’s still 10+ years old. Well, too bad that part is NLA if it’s a common fail item. Hopefully I can find a used one that will give me a few years.
Thank you for the help. Really appreciate it!
Might be best just to let your saturated cap dry out for awhile, no need to replace it before verifying it’s not just wet
Very unlikely. The switch itself is a sealed unit. The float contains a magnet that rises and falls along a plastic guide.
And brake fluid is not water. It won't just evaporate.
To each their own 😉 it worked for me and a friend to eliminate the dim glow after overfilling, albeit I used a hair drier (maybe pure luck the magnet let go). I know us cruiser guys love replacing cheap parts so I wouldnt blame you
