Digital Torque Wrench - Special
Status
Not open for further replies.
Brown Line Metalworks is a manufacturer of Digital Torque Wrenches. We thought they would be of interest to members of this forum, so we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: MUD
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid till Nov. 15th, and is only for the lower 48 states.
Nice looking tool, any plans on producing on that starts at 0 in/lbs?
what's the warranty on these?
Our warranty is industry standard: 1 year from date of purchase, 90 days for calibration. We have a repair/calibration facility located in Chicago in case anything ever does need to be done to the wrench.
BLMW
We do have plans to come out with both a 1/4" and 3/8" version in the in.lbs range. However, it will not be available till late next year.
BLMW
Where are your wrenches made?
The ratchet and the steel components of the wrench are manufactured in Taiwan, and the electronics and assembly are done in Malaysia. Our repair / calibration facility is located in Chicago in case anything ever needs to be done to the wrench.
Our wrench is manufactured using our patented technology, which is inherently much less expensive than our competitors. That is why we are able to offer the wrench at such an attractive price.
BLMW
Status
