Anyome have a good suggestion for. Digital temp gauge to use on my 94(OBD1)? Wish I could get a scan gauge.
This is the one I installed a couple of years back. Works like a charm.
Koso North America Ex-01 Water Temp Meter with Adapters and Clamps - 2Wheel
You need to make sure you buy the correct sized adapter.
I used glowshift 39 mm. You can also tap into the flat spot on the radiator outlet pipe.What adapters are needed! That is perfect!!!
Why don't you get a ZF OBD1 scan tool? I have the plug in blue tooth version on my 94. It reads fine from the drivers seat and the ZF scanner pluged in under the hood. A newer version is coming out this year that allows us OBD1 owners to also read trouble codes. Its about $35.00 or so.
ZF: TOYOBD1 Android datalogger :: Engines supported
