Difficulty Shifting
Greenville South Carolina
Needing to be more deliberate with using force to shift from park to drive/reverse. Wondering what the cause might be.
Transmission mounts maybe?
Anyone else experiencing this?
'15 with a little over 110k miles.
I'd take the plastic off around the shifter and see if something has gotten into the shifter like coffee, wife's hair tie, lego block. Next I'd check at the transmission for anything binding. These are cable actuated, right? I don't think they are fully electronic.
Actually I'd probably check the transmission end first. I'm leaning towards crud somewhere or bad cable. You been in the mud recently?
I don't think a bad motor mount would cause this as that's typically only a symptom with old school linkage type connections. I'm thinking our trucks use a cable.
let us know what you find!
There are a few threads about this issue but I belive no real solution has been found. Mine sufferers from this but it's intermittent
This is constant.
Initially, I thought it was me. Just over a year ago, I bought a F-150 for towing some stuff, then in short order it became my daily and the 200 became my wife's daily. I drive about 35 - 40k miles a year, making the truck my daily made sense.
So, my first impression was having not driven the LC in a while, I'd forgotten how shifting felt. My wife brought it up recently though, so it's getting worse.
Here are a couple threads, but there are more.
The one below claims cleaning the MAF fixes the issue.
Mine has done this since new in 2015. No real issue and no real ‘fix’ that I have found. Seems to be strongly moisture / humidity related with my vehicle.
Appreciate the thread links there, lx200inAR.
stonepa, interesting. It was particularly humid here when my wife mentioned this last week.
yes - I have a 15 and had this issue - particularly after a lot of wet weather, puddles and sitting in damp conditions. had it going for a year or more and it was frustrating.
some threads on here talked about doing a MAF cleaning and that it resolved the issue... i was skeptical, because I have no idea how a MAF would would be implicated in this, but it does turn out that there are some interactions between the shift linkage, trans temp and other ECU stuff I cannot explain.
So I did the MAF cleaning when I was in for some other service - i've not had the problem since.
buy a can and get to it? (remove maf from vehicle)
Cleaned the MAF up recently. Had to take a brush to it in addition to the cleaner.
Pleased to report this indeed remedied the shifting issue. The difference was immediate, shifting like new.
