Difficult to solve ABS code
With the engine off (but key in "on" position), I was getting straight battery voltage or about 12V. At this point, I would now measure downstream and see if you get 12V there.
I can't assume your '97 is wired the same as my '94, but behind the driver's side kick panel were several plugs, and the ABS computer. There were roughly 4 black wires with white stripes in the mess I had in there, and one of them had the silver spots. However, that wire converted to just black/white as I went upstream from the decel. sensor once it got to plug ID2 as in the above diagram, and my wire was at pin 3 if I recall correctly. On the other side of ID2 the wire was just black with white stripe (no silver spots). The other three black wires with white tracers were 1) the IG wire going to the ABS computer 2) going to alarm 3) going to a plug behind the cargo panel over the rear driver's wheel well (that I'm not sure what it's used for). But they are all ignition activated, meaning getting 12V once the key is turned to "on."
You can verify if you've isolated the decel's black wire with white tracer and silver spots by disconnecting the plug at the decel. sensor, then unplugging ID2 (if your '97 has this plug), and measuring continuity (ohms) at both ends of the wire. Then, plug them back in and measure for voltage at ID2. From here, I am not really sure where my decel wire actually hooked into from the factory, because I essentially found one wire loose and not tied into anything due to human error (previous idiot owner). I also think they taped it back up into the wrong mini bundle of wires (but I could be wrong). My loose wire may have come straight from the steering column, as it appeared to tie into a bundle that went up into the dash.
If you are able to measure about 12V at ID2, then it would seem as if you too have a break in your wiring somewhere between the kick panel and sensor. The two likely spots would be along the floor board under the entry sill plate (due to water/corrosion), or at the center console if someone has had that out before (easy to pinch the wires).
