Difficult to solve ABS code
Minnesota
*SOLVED*
see post #10 further down for the cause.
Here is the original post:
Hello, I've had a particularly difficult-to-diagnose ABS light issue for about 6 months now. It's code 43, decel. sensor (under shifter console). I've tried numerous things to fix it. I *may* have a fix, but I need to ask if there's anyone that can try hooking up a multimeter to the "IG" wire on the decel. sensor to see if it is supposed to read ~12V with the ignition on. My wire doesn't show any voltage at all (FSM doesn't clarify what the wire should read).
What I've done so far:
I've replaced the sensor, computer, all 4 rotors/brakes, checked wheel bearings, greased drive shafts thoroughly including pulling slip yokes apart and greasing manually, and adjusted the throttle cable going to the transmission (it was a bit loose and was causing a clunk at about the same time the ABS light would come on, but it tight now). It is NOT A WHEEL SENSOR (wrong code). I inspected all the sensors and they were all fairly clean, though I cleaned them anyway. I've also tried adjusting the installation angle (front to back) of the decel. sensor but no luck.
Symptoms:
ABS light comes on only when coming to a stop, at about 10-5MPH just before I've stopped. I thought it was tied to a driveline clunk, but that has since been fixed. I further "eliminated" the driveline from being a possible source by shifting into neutral each and every time just before I stepped on the brakes, and shifted back into D just after I lifted my foot off the brakes. So, I was never in gear while stepping on the brakes. However, the ABS light would still come on.
A few things that may be pointing towards a cause:
1. Possibly of most importance, the decel. sensor has 5 wires on it, one of which the FSM labels as "IG" which I take to be ignition. The FSM doesn't clarify if this wire should be constant ~12V or not when ignition is on, but I'm getting 0V. It would be AWESOME if someone could try verifying if their IG wire has voltage or not. I just stuck a multimeter probe inside the rubber dust boot on the backside of the plug and grounded on the shifter bracket. To know which wire is the ignition wire, look for the solid black wire with white tracer on the vehicle side of the plug. On the sensor side, the wire color changes to red. Other wires on the decel. sensor (vehicle side of harness) are a ground (white with black tracer), and I don't know if I have the letters correct but something like SG1, SG2, and SGT. I get voltage on 1 and 2, the ground is properly grounded via OHM reading. I don't know what SGT is supposed to do (FSM doesn't clarify).
2. The FSM refers to the diagnostic plug under the hood and connecting Ts and E1 (not the same two pins to READ ABS codes), and this is supposed to cause the ABS light to flash 4x per second. Then the FSM says to take the truck for a drive and watch how the pattern changes (it's supposed to change during certain circumstances). However, when I short the pins on the diagnostic plug, my ABS light comes on and stays solid. It never flashes. I remove the connector, the ABS light turns back off (assuming I've cleared the code already). The light not behaving correctly must mean something, but I'm not sure what yet.
3. I cannot clear ABS codes by stepping on the brake pedal repeatly (FSM says to short two other pins on the diagnostic plug and tap the brakes 8+ times under 3 seconds). I have to disconnect the battery to clear the code. Not sure what this means either.... The code clears immediately after I disconnect the battery.
4. After I've cleared the light, it seems to come on at about the same time, meaning after about 20 stops. I can pretty much predict when it will come back on. The light does NOT come on only after the 1st stop. It takes around 20-ish stops. And it only comes on right as the truck is about to stop (under 10mph). It has NEVER come on while braking at high speed.
I have this same issue and have seen a few other posts about it over the last few months also.
I will check for voltage this afternoon and report back.
@cruiserdan may have some insight on this?
The BLACK/WHITE "IG" wire should have +12V when the ignition is on.
Try checking the 15A "ECU-IG" fuse.
All fuses look good, including the final 7.5A fuse by the steering column. According to the FSM wiring diagram, a "main" IG wire leaves the steering column and head's towards the computer's incoming "IG" wire, but before it gets there it splits and sends a branch to the decel. sensor. I have no idea where this split occurs. I "think" I checked the computer's branch of the IG wire but I don't remember. i will check it again tonight. If it has 12V, and the FSM wiring diagram is correct (and I'm following it correctly), then the sensor's IG wire should show 12V too. So, perhaps there is a break in the wire somewhere. I don't look forward to tracing it, thus I'm trying to confirm before I start pulling the seat out to follow that branch of the harness to verify if the black/white IG wire should actually have 12V and if I can find a break.
The other culprit could be the "ID2" connector, which is where you would trace that BLK/WHT wire back to.
The connector looks like this:
And you will find it here:
The "IG" wire should be on pin #15.
Wow--nice work! Does your FSM show the pinouts on ID2? I had gotten my copy of the FSM off this site, but I'm wondering if I'm missing parts of it or if stuff is shuffled around. For example, there's a "radio.pdf" document misplaced in either the driveline or ABS folder.
It's the electrical wiring diagram (EWD) that you need, it's separate from the FSM.
The EWD isn't organized by connector, it's organized by circuit. Multiple circuits can share a connector so the information is spread around.
The good news is, I'm about to fix about 30 problems that are either already occurring, or are going to occur eventually. Almost the whole bundle of wiring harness running under the driver's side sill plate had been hacked into by some previous owner and taped back up again. Numerous wires had sheathing cut off in short sections, seemingly for no reason (aftermarket alarm hack maybe?), or 4" sections of wiring removed at random locations, with crappy wire spliced back in and wires twisted together. Electrical tape was used, but they simply made little "flags" hanging off the wiring. Much of the wiring was corroded, and at least two wires corroded completely and weren't active. One of which explains why the O/D button never worked. I have repaired about 10 wires so far but have many more to go through.
One of the decel. sensors is one of the ones that was hacked, the "IG" wire mentioned previously, but it was still intact and showed connectivity from the ID2 plug all the way to the decel. sensor plug. So, I don't think "IG" was broken, even though it had been poorly spliced. But even at ID2, that black wire with white tracer and silver spots is still showing no voltage. It also goes to a different pin on ID2, "three in" from the end of the plug, though I don't recall which side. It did not go to pin 15. From there, this black wire comes up out of ID2, like it was going to go up into the dash, but then loops right back down again to the floor board and back along the driver's door sill. I followed it back to an unused plug under the driver's seat, which I believe was for a factory alarm (that is missing).
There was another wire, red with blue tracer, that runs passed the driver's seat and keeps going to the rear that was also completely corroded and inoperable. I don't know what that goes to, but I've also fixed that one.
I still have about 20 more splices to fix before I know if any of this fixes the ABS issue or not. Four of the 5 wires going to the decel. sensor are NOT spliced and are theoretically ok. I do wonder where that black "IG" wire runs to in the rear of the vehicle. I don't know if I will be "up" to manually following it back. If it does still hook up to the ignition switch somewhere, this would be an awful strange path for it to take.
:eek:
FIXED.
WHEW.
After going through probably 50 wires going along the driver's side sill entry plate, I found a black wire with white tracer that had been cut at some point, that must have been loosely pigtailed "somewhere" very poorly at some point, but had come apart from it's sloppy pigtail and was just loose inside the bundle. I'm not sure where it had originally gone or been pigtailed to, because I had already fixed all the rest of the wiring and never did see anything obvious (e.g. never saw two halves of a wire that looked like it should be joined back together).
Did you happen to take a photos of the location you found this? I have been having the same problem since I got my truck, have done very similar changes as you started out with, but ABS light stays on no matter what. Used to be sporadic, would turn on and off, now always on.
No photos, but it's easy enough to describe. But before inspecting the harness, the first thing I would recommend you do is pull the shifter console and verify if you are getting 12V measured on the black wire with white tracer and silver spots--when the ignition is turned on (if the ignition is off, the wire will read 0V). There's also a white wire with black tracer, but that's going to a ground about 12" away. But go ahead and measure to make sure the white wire with black tracer is indeed grounded.
As for the location, I peeled open the entire bundle that runs under the driver's side plastic door sill trim (which is also part of the driver's side kick panel). This bundle was made of up separate smaller bundles, the smallest of which appears to go to the plug under the seat and is meant for a factory alarm. You access this bundle by pulling up the sill plate/kick panel, peeling up the carpeting along the door jamb, and removing a plastic retainer strip that has a large corrugated wire loom inside of it. And within that are most of the wires. The bundle meant for the alarm ran separately and outside of the corrugated tubing.
My wires were damaged in various locations between the kick panel, all the way back to the front/middle of the driver's seat where part of the harness splits off and goes to all the stuff around and including the shifter and decel. sensor. Most of the wires were damaged within the first 10" of the door opening (meaning where your feet slide past when you get in). Since this wire loom basically lays on the floor, it's subjected to water/salt/dirt etc.... Any break in the sheathing (such as idiot-splicing) will guarantee corrosion. But before you go to such lengths as taking all of this apart, see if you have 12V on that black wire with white tracer and silver spots at the sensor plug. It was at least a couple hours of work just to remove copious amounts of electrical tape and get all the wiring exposed along the sill--work you would want to avoid if you don't need to do it. But if you aren't getting 12V at this wire, then there is a break somewhere.
I don't think I can edit the title? I did update the first post to say *solved* but didn't see a way to update the original title.
At the top of the thread there is a link on the right called "thread tools". It's a drop down with a link that says "edit title"
I have taken that console off quite a few times, fiddling and changing the decel sensor and also the 2nd and PWR buttons, will check the wire voltage tonight, thank you!
It's been a while since I've seen a newer 80 like yours, but I'm assuming the 2nd and PWR buttons are the two small buttons down on the shifter trim/console (I had a '96 several years ago).
Other symptoms/problems I had, that are now fixed:
-dome light over rear seat didn't work (it used to, but quit working about 2 months ago).
-I never knew I had a seat belt warning light until I made the repairs.
-My O/D button works now.
-and my infamous code 43 ABS light.
-I had several wires that were about to fail, either due to corrossion or due to crappy pig tails falling apart, so there was probably more that was about to fail that I didn't even know about yet.
The common denominator was all the wiring passing through the same damaged section of bundle. Hopefully, your harness was not butchered like mine was, but perhaps your wiring has been cut/damaged in other ways and wires are corroding. My butchered wiring appears to be the attempt of someone to install an aftermarket alarm (that is since long gone). But there is evidence that there had been an aftermarket alarm, including a generic pin switch under the hood, and tapping (poorly) into the door pin switches.
