- Joined
- Jul 2, 2003
- Threads
- 132
- Messages
- 950
- Location
- Glen Waverley, Victoria, Australia
- Website
- jonathan-ferguson.au
I've always had a bit of Axle Tramp(not Wheel Hop), but these days it's quite gnarly.
I replaced the rear Leaf Springs about one and a half years ago and the Axle Tramp did subside, but it's back as gnarly as ever, particularly after I replaced the flogged out Rubber bushes with Polyurethane and all new Pins.
Also, since replacing the Rubber bushes in the front and new Pins and Shackles, I'm getting a huge amount of Dive in the front under heavy braking that wasn't present prior. - The Torque Rod has always been present.
With the Rear third member, when I put the Diff in after the Lock Right install I torqued 'em to the spec of 25Nm, then when I noticed the Diff puking previously(one year afterwards) I torqued it to the specs between an open Diff and an LSD of 26.555 ft/lbs., the next time I whip out the Torque wrench I'll tighten the Nuts to the LSD hausing spec of 47Nm. - Only a quarter of the Nuts need to be increased in Toque, those are on the left side bottom half.
Is this a consequence of Axle Tramp, and is anyone else getting these symptoms?
I replaced the rear Leaf Springs about one and a half years ago and the Axle Tramp did subside, but it's back as gnarly as ever, particularly after I replaced the flogged out Rubber bushes with Polyurethane and all new Pins.Also, since replacing the Rubber bushes in the front and new Pins and Shackles, I'm getting a huge amount of Dive in the front under heavy braking that wasn't present prior. - The Torque Rod has always been present.
(I'm laughing WITH you J, not AT you)
To do list.
