Differential Gear Setup --How To--
I know you skipped the step of pressing the bearings off... but that's what has me stumped. I can't get my bearing splitter under the carrier bearing on the locker side because of the bolts on the end of the carrier. Nor can I figure out which tool to use to remove the old bearing. I know there's probably something simple I am missing here, but I really don't know what it is!
do you know if the pickup uses the same size side adjusters as your 80?
i need to make some, i have time to do my gears this weekend.
its on a 1985. what are the specs of the too you made? i need to build it this week. thanks
I'm going to follow this thread for my R&P next month. Curious, since I don't have factory lockers, will I need to order bunch of shims before I start?
gears
The models w/o factory lockers use side adjusters not side shims. Our kits have all these parts in them
Got it. I didn't think I saw any shims when the ARBs went in but couldn't recall for certain. Good to know.
Thanks.
So when setting up the gears on E-lockers, would it be a good idea to have several shims at the ready? I bought your master install kit, and unfortunately it's in storage and I haven't looked that closely at it, so I don't know if it has the various shims included or not.
Thanks,
Jack
Thanks,
Jack
The only shims included in a kit is the pinion shims and they are the ones that place behing the bearing race. Toyota shims go behind the bearing on the pinion.
The carrier shims can only be had from Toyota AFAIK. They will run you over $80, unless you have a parts account or possibly order through CruiserDan.
My I also strongly suggest using the OEM crush sleeve and not the aftermarket one supplied in the kit. The OEM nut is also better IMO. However, I did order the kit, mainly to see what it had and for the paint but since Zuk at gearinstalls.com did mine I sent the kits back.
Sorry didn't mean to skip this, I guess I missed this question. The adjuster tool I made initially was for the diffs on my '86 truck. So if you make something similar it should work, I have the details of the tool listed above.
