Different Size Tires
Maryland
TLDR; Drove for ~150 miles at speeds up to 70mph with 275/60R18 on front left and rear right and 275/65R18 on front right and rear left. Did I damage my diffs?
My 2003 LX470 came with two different size tires on the front and back. 275/60/R18 on the front and 275/65/R18 on the back. Not ideal, but ok since most driving is just around town. I had a wheel shop repair some corrosion on the wheels that was causing minor leaks and they must've not realized that there were different size tires and put them back in an X pattern (see TLDR above). My son then took the LX camping with his friends and had to drive ~150 miles round trip on highways to the campsite. How much damage has been done here?
Unless I'm being dense, you're talking about the same width tyres, same wheel size, but different sidewall height. E.g. 65 Vs 60
That's about 1" different, so I wouldn't expect any damage has been done at all, especially if you consider possible variances in tyre pressures etc.
Happy to be corrected here, but I think you're safe!
OP is talking about a 31" vs a 32" tire (3.5%), so the smaller one has 22 more revs per mile.
@RustSchmust do you notice anything now that makes you think something got damaged. Can't undo those 150 miles, but they won't necessarily grenade your differentials.
31” vs 32” diameter is exactly what I was worried about. Didn’t notice anything specific but the vehicle is still pretty new to us. Up around 70mph there was a little vibration but that could be anything. I’ll keep an eye on it. Appreciate all of the responses.
The number that comes up often here as a rule of thumb: tires kept within about 1/4" to 1/2" of circumference of each other, or measured a different way, within about 2/32" to 4/32" of tread depth difference. That's reasonable uneven tire wear and the figure cited in a few threads on the topic, but not a number everyone agrees on.
Regardless of exact tolerance, real-world consequences reported range from mild (nothing noticeable) to severe but isolated anecdotes like that aren't proof of a specific threshold, just evidence people take it seriously. Also remember the conditions these trucks are built for: third world infrastructure and supply chain, where getting 4 of the same tires is not guaranteed.
Interestingly, the 99 FSM describes ABS DTC C1237/37 "Tires of Different Size": it triggers when 1 or 2 tires differ in size, detected while driving over 12 mph for more than 20 seconds, three times in a row. This is a wheel-speed-sensor plausibility check for the ABS system, but I wonder whether it's set at the drivetrain protection threshold.
