Different seat in 80?
Houston, TX
Website
www.teqoutfitter.com
Has anyone swap a different seat into an 80? I mean like seat from BMW, Volvo, Lexus or 100 series LC that provide better suport? Or new cushion with new leather is good enough? I like the new is300 seat, GX470 and even RX350 better than our 80 series seat.
80 series seats suck. The Corbeau Moab I think would be an excellent choice.
I ended up having mine rebuilt at a local upholstery shop. They put a ton of softer material on top of the old, getting rid of that pit in the seat and raising it up. It's awesome. Cost me two bills, everything still looks factory.
Doing the passenger seat shortly.
Was just getting ready to post the same question. I HATE the seats in my 80, they leave me with a back ache and they're too close to the steering wheel. I can fix the brackets, but I need to find a better seat that doesn't cost $300+ per seat.
Any other feedback on different seats experiment? I don't want to spend $1k on getting new leather and cushion pad and not getting the result I am looking for. I would rather pay $300 for a set of GX470 or RX350 seat and fabricate the seat mount.
well I am about to reference that same issue but I am just going to solve it with new/better padding at an upholstery shop
X2 on the seats sucking! I had a set of Corbeau Moab's earlier this year while my OE seats were getting redone. The increased leg room was great. They do sit a little lower than stock so I had to use a couple of spacers to lift them up. There are plenty to be found on Ebay, Craig's, et al... Brackets will set you back about $175/pair
Someone on the 60's forum put Volvo V70 seats in his 60. Search Volvo and it should come up. He loved them, and I had always heard Volvo makes the most comfortable seats. I have been tossing around the idea of doing this too. I don't find the 80 seats that bad, but with real long seat time they start to get crappy.
I got a deal on a leather kit from AATLASX on the board. Goofy color combo helped (orange and grey) as did being for an early 80. $250 to the upholstery shop to install the leather and rebuild the foam. Feels like a brand new seat from a totally different vehicle. Comfortable to ride in for as many hours as you can keep fuel in it.
I find the LX seat is more comfortable than LC seat as it is softer. I just have not sat in a brand new 80 seat yet. So you guys are saying with new pad it is still sucks?!!
When the time and funds some , MasterCraft 3G seats...FULL suspension seat and the definition of comfy. Only downfall is no back adjustment, so not too practical if you're daily driving I guess.
I would go with a suspension seat though and they do have them with all adjustment available. AMMO on the board has Sparco Seats in his 80.
I ran 1st Gen IS300 seats in my 80 for several months. I'm now back to stock seats and here is why...
1. Stock 80 series seat rails are relatively close together(width), i think there is something like ~14" between the mounting holes. The is300 seat rails were about 16.5" apart and this was one of the thinner mounting widths i found. As a result, this required raising the seat up to clear the tranny hump. At 5'10" i was the tallest person that could fit in the seats.
2. A combo of this awkward height and "sports car" seat ergonomics made the seat put an incredible amount of pressure on one's thighs. For short distances is was fine but over an hour and i was wanting stockers back.
I think the key would be to find a seat with the most narrow rail width possible. I got detailed measurements on Tundra, Cressida, and 100series seats(all of which are more comfortable that 80srs. imop) and unfortunately I ran into the same problem as the IS seats had.
Below is a quick picture. I had the bracket fab'd up and it came out great, very stout, clean, but the height problem killed the deal.
I find my cloth seats a lot more spacious and comfortable than leather. ONLY, I really want an armrest!
I agree, going from an 97 LX to a 96 LC, I would gladly take my LX seats back. I want to either put LX seats in or have my LC seats redone with LX foam and some Atlas leather.
Jack
Thanks for the feedback. Can you give me the measurement on 100 series seat? Thanks.
FJCruiser?
Has anyone sat in an FJC? They're pretty comfy (although I don't have any long term seat time in one). Plus the seat bottom height is adjustable.
This is the route I'm most likely gonna take. Assuming I can ever get them at a price I can afford.
What kind of measurements are you talking about?
The brackets seem to be the key to fitting a different seat in the 80.
The 100's brackets are just too far apart and require narrow, which means messing with the power motor, or cutting into the tranny hump.
Dispite that, i'm happy to get measurements if you tell me what you want.
The one reason i gave up on the 100series seats too was b/c price. Try and find a clean pair of 100 seats, they're pricey. I think some late 90's Lexus LS400 seats would be alright, maybe even RX300's, they have a nice armrest i think.
Here's something I tried on an 18YO FJ62 seat's cloth upholstery:
  1. Remove bottom seat cushion & upholstery from same.
  2. Cut a piece of 1 inch Memory Foam to fit. I just cut a section for the central portion, but IF I were doing it again, I would also cover the bolsters. FOAM will compress.
  3. Spray OEM foam & Memory Foam with Spray Adhesive. Tack together per instructions.
  4. Pull upholstery back over seat cushion, Memory Foam will collapse to assist stuffing cushion into upholstery.
  5. Secure upholstery with new hog rings (using new rings & hog ring pliers - Tractor Supply, etc.).
  6. Wipe smile from face, look over at :princess: & ask her to let you know how the upholstery is holding up on her side.
In hindsight, (:D) I believe I would try 1.5 or 2 inch thickness of Memory Foam. The thicker you go, the more comfort BUT (:grinpimp:) the more difficult it will be to get the upholstery back over the foam.
I had scrap foam left over from putting a King size Memory Foam mattress pad (Overstock DOT com) over a Queen size softside H2O bed. $40 investment + adhesive.
Interesting. So you did not replace a new pad but use your old one? Anyone here with new pads and leather please commend.
