Differences Between Mid-'70s Hardtop and FST Windshield Frames?
4Cruisers
Is there any difference between the hardtop and FST windshield frames? The spare windshield frame I have is for the later windshield wiper motor location on the lower right, like on my '76 FJ40 hardtop model. The spare frame has an extra hole right and left on the back face of the frame up high, below the top bracket. And there are snaps screwed into the windshield frame at various locations. I don't know if the extra holes and snaps are stock, or if some PO added them for a bikini top. Other than that, the windshield frames look the same.
I know I had to add snaps on my 68 when I added a Kayline soft top. Think all the extra holes were added. Have 75-77 windshield and it has provisions to run either a hard top or soft top. I always wonder why PO opt to drive holes in the windshield frame and use sheet metal screws to add a bikini top channel meant for a jeep instead of driving the bikini channel and use the factory installed fixed nuts. Lazy I guess. It would require taking some measurements. Have what I believe is a 82+ windshield frame (has two wires for dome light) that has the empty holes without fixed nuts and a row of holes for sheet metal screws from a PO. At least PO added holes are easier to deal with then rust.
Bigger difference in the windshield between 74 and 75. Went from using four bolts to secure the hard top to just two. The later hard tops are not notched for the wiper arms. When I had my 73 FST stored outside at the cabin I used a 77 hard top. Had to remove the wiper system to get it to fit. Since it was only to weather tight opted to do that verses cutting the front lip on the hard top.
One of my windshields didn't have the 6 or so threaded inserts along the top edge but it did have the holes for them. Not sure why. This frame was one with a washer nozzle mounted top center and the rubber grommet on the inside. I believe that narrows down the year.
