I know that the lugs are different between the years. I know some are conicals and the others are shanks.
But what are the major differences between the years? Are the offsets and backspacing the same?
I'm asking because I'm looking to upgrade from a 91-92 style to the newer 93-97 styles.
I think the only useful difference in stock wheels is the size. 91-92 were 15", 93-97 were 16". Biggest problem was caliper interference if you tried to run the 15" on the 93-97s. HTH
Yup, the 40th Ann. wheels have some gray paint on them. The Lex LX450 wheels are painted as well and also have ridges along the wheel arms. But these are just cosmetic differences. There ar no 'technical' differences such as backspacing, width or strength.
Below are the LX450 wheels (notice the grooves along the arms) and also colored 'holes'. The 40th Anniversary wheels have just paint around the 'holes'.
The '93-94 wheels have a steel insert and must use the conical lugs.
The '95 wheels use the flat washer style "shank" lugs.
The '96-97 wheels (LC and LX) use the flat washer style "shank" lugs.
The '96-97 LX wheels are styled different per above pics.
The '97 "CE" and '97 40th wheels are styled different (different color paint as mentioned above)
As you know, the '91-92 wheels are 15x7".
Both LX and LC wheels made for '93-97 vehicles have 6 on 5-1/2" bolt pattern, 0 offset (4.5" backspace), 16" diameter, and 8" width. The center bore is 106mm for 93-97; LC and LX.
As Dan and others have mentioned, you can use later rims on the 91-92 and you can use 95-97 rims on your 1994 (with correct lugs for the wheel). The OP asked what the differences are so that is what was given in my reply. If you don't care about appearance, you can mix LX and LC rims (or standard LC rims with CE rims, or ... )
The OP didn't ask, but the biggest issue on fitment is the 91-92 15x7" rims on 93-97 vehicles.
