Howdy everyone--
I'm in the middle of rebuilding the '73 FJ40 differential (first timer). PO had used brass shims to set the pinion preload and they went to pieces, bearings all ruined. Anyway, I got the bearings all in, the preloads set OK, backlash OK, my question is that in order to get a halfway decent gear pattern I had to go with no shim at all under the inside pinion bearing--is this normal or did I do something wrong? The old bearing had a .45 mm shim under it and gave a good tooth pattern, could a new bearing be that different? Both new and old bearings were exactly the same size. . .
Thanks!
Thanks!
