Following.
Update: pulled circuit board from ecu and checked the 4 diodes for continuity and holding the plugin to you the top right diode has none. The other 3 do. Diodes i think only alow current to flow one way or cleans up the signal? So i think that diode is toast.
Any one know what those 3 black deals are?
There is a place for one to be there but it is not,should be between the light relay and the antenna ecu right
I tested the cdl relay and the only one that functions, clicks is +12v to pin 9 and ground to pin 10 bottom left. So i will see if I can get those relays and rebuiled the cdl relay. what du you guys think. Thanks for directing me to those threds stucknKS
I was cleaning the in side of the cruiser noticed this
so I went digging and found this D-4
Those 2 plugs up top there are the remote mirror sw and the rheostat sw the other should be dam well looks like it D-4 the front and rear Diff lock sw. D-4 has 5 pins 1,2 and 4 are used, 3 and 5 are empty. That should be the plugin for the rotary diff sw to lock the front or the rears ??
And I also have this now
Is this standard to have both diff locks in a cruiser?
