Has anyone had this problem?
Brand new rear locker.
Bench tests well with 9volts
Plugged in OEM and with Rotary RR activation the locker tries to engage/disengage but needs help from a pry bar!
Note: Shift fork slides easily when disconnected.
So I take it out, grease the shaft, re- install and run it through many cycles using #1 and #2 with a battery,works like a charm... almost instantly.
Great right, wrong, plugged in it wants to work, but seems like the power on/off cycle with rotary to ecu is to short, therefore not allowing full spring wind up in either direction.
Have a new to me ecu coming via mail, but in the meantime I'm open to suggestions.
End Cap:
New locker
Wiring works
Shift fork easy to move when disconnected
Works like a charm using a battery to #1 and #2 and shift fork connected.
Wants to work when connected to OEM wiring harness but needs help in either direction.
BTW: Greasing the shaft end really increased the speed of locking/unlocking, did this just because the original locker shaft looked like new but shaft was dry.
End Cap:
New locker
Wiring works
