Diff gear ratio/Hmmmmmmmmmmm?
So I got a 72 40 with a 3 spd, usual stuff. Wasn't sure if I had a 3.7 or 4.11 difs.
I was always under the impression that you turn the pinion 3.7 times and the ring gear, hence the axle will turn once, resulting in one revolution of the tire.
So I slide under my rig, mark a spot on the tire and one on the driveshaft and dif housing.
I turn the drive shaft only a little over two turns and the tire makes one revolution.
What gives, wear did I go wrong.
Any thoughts?
I got it its two revs of the tire then and count the turns of the drive shaft.
Read the post in the link....or just think about it. ;)
Even easier for you....
fj40owner said:
Another way to determine your r&p ratio is to place transmission in neutral and elevate one tire. Mark tire and driveshaft, turn tire two complete revolutions while counting number of turns of the driveshaft. This is your Actual Gear Ratio. i.e. 3 turns + 3.00 ratio, 4.1 turns = 4.1 ratio, etc.
Hope that helps!
Good luck!
-Steve
V-DAWG said:
That way whenever you want to shift into overdrive just pick up one wheel and hold it still. :D
