A trick with the mini-truck guys is to get Allen head diff drain plugs that you can buy from Toyota dealers or a few Toyota aftermarket parts suppliers. This keeps the plug flush and the factory ring should protect it. Even if the plug gets banged up, you can still get it out.
Funny, they always said this was a Land Cruiser plug and that's why you can buy it at a dealer, but I don't see any of these on my 80 series.
Here's one source, about half way down this page:
http://www.marlincrawler.com/htm/diff/cruiser_diff.htm
Some run a bead around the ring to build it up, some weld the drain plug in and remove the lower diff studs to drain.
What diff studs are you talking about Kevin--the actual studs going around the cover of the pumpkin? Seems like an aweful lot of work to drain fluid (gasket/FIPG, 14 nuts) vs. one plug.....
I see the allen-head plug thingy, but my question is what happens when the ring around the plug gets mashed over top of the plug? Even though you can get the allen bit down onto the plug, it still won't unscrew because the outter ring-lip is mashed on it.
CJ,
The outer ring is a soft malleable metal that you should be able to 'unmash' (is that a word?) with a screwdriver or a small chisel. The problem that I had with the stock hex plugs is that the edges and points get messed up and a 6-point socket won't fit on them even after you 'unmash' the protective ring.
-B-
I clean up the ring with a die grinder, small carbide burr combo. The ring is relatively soft metal, adding some weld makes it wear better.
3/8 th's plate is tacked at one end then pounded/tacked all the way to the other end.
