Diff Breather article?
Truckee, Tahoe, CA
I have searched and searched and can't seem to find this. I've seen Scolaro's article, but I recall reading a much more step-by-step article. It listed the exact list of materials needed and it generally was more noob-friendly. It might have been in the faq, or on another site. Anybody know where I can find this?
:confused:
Are you talking about the one from toyota trails? If so I bet you could search waterproofing and find it.
thanks
This is a mod that really needs no instructions.
Buy a bunch of 1/4 fuel line-roughly 20-25 feet. Start at the rear breather nipple. Measure the amount of fuel line you need to reach the top of the firewall. Run the line from the nipple leaving a bit extra to accomidate axle droop. Then run forward to the firewall and up the fire wall to the top. Attach a 1/4 inch inlet fuel filter. Do the same for the front axle. There is no need to combine into one breather unless you want to.
For the tranny and transfer-1/4 brass t and combine the two existing breathers into one. Run new line to the top of the firewall and cap with a fuel filter.
I have found I need to blow out the rear one from time to time with compressed air.
Thanks, I didn't know how much tampering with the diffs it involved. It doesn't sound very extreme at all. I'm going to be crossing the Carson River at Barney Riley in 2 weeks and don't want to mess up my diff oil.
No tampering at all. Pull off the existing breather, the nipple is right there. On my 80, I ran the fuel line breather down the frame rail attached to the brake lines. You need to be creative around the fuel tank. On my other trucks, there is better access to the inside of the frame rail and the breather runs through the frame rail to the front of the vehicle. This is a no brains 1/4:banana: mod. Just do the first one, and you'll realize how simple it is. You'll have both axles done in 20 minutes working slow. You need to be a bit more careful with the tranny and t-case breathers.
Regarding deep water-even with breathers, when you get home, I strongly recommend that you drain the diffs and refill with fresh gear oil. It's cheap insurance.
motorized variable height version:
:flipoff2:
If you had a snorkle, you could run the breather up inside it to get it waaaaaay out of the flood zone... unless you wheel like your 80 is a submarine :eek:
