over it ( 14PSI ) you are making more hot air than usefull boost .. an intercooler ( good one ) it's a must .. are you running a hood scoop ( a pic .. ? )
I'm in the intercooler boat or water injection which it's my next recomendation to you ..
the smoke means you have too much fuel. depending how much it could be affecting performance. You need to take it to a diesel specialist to get it tuned right.
Although after that any increase is likely to me minor. The only way you're going to get more power and better performance is by twin turboing or supercharging plus major boost (20psi) You will however be stressting the motor quite a bit, and when things break it's very expensive to fix on the diesel motors.
You also have to keep power to weight in mind. these trucks weight 2.5 tonnes. Realistically you can get about 190kw out of the motor without compromising reliability too much. that still puts you in the same power to weight category of a decent small car like a toyota corolla. Then there's aerodynamics to consider.
Fact is you're not going to get big speed out of a 1hdt. You have to go a modern v8 petrol to even consider matching the performance of a modern large car.
the attitude of the world.
The cumming 6bt is more than capable of 1000hp
with diesel we can inject at the perfect time
we run huge compression
and huge boost
out only limitation is heat
why would i want to pull this engine out to put in a dopey chevy
Mate i hate to say it, but Cummins are built more robust than our Toyota 1HD's. They all seem to run decent boost from the factory and can easily take even more. We'd all love 30psi of boost, but it aint gonna happen reliably with a 1HD-FT.
I would like to see it though!
Once you start to put high boost pressures into our Toyota turbo-diesels you start to loose reliability and you break stuff. Of course you could probably rebuild it with a set of different rods & pistons etc, but you'll be throwing a heap of cash at it and in the end it could still all end in tears. Good on ya though for being ambitious!
