Diesel conversion
Kamloops, BC Canada
Website
www.shopraddcruisers.ca
I would love to run the 1HD-FT or just T, only question is I can buy a lot of gas for 10K.
Only other thing pushing me is the truck has 250000miles, but runs like a top and gets a 12MPG :-[.
I have heard the FT motor can get a generious 26MPG.
And if Jim is reading this please update us on you 1HD-FT conversion.
Yep, Hi Rob
I'm several saturdays into the swap with Ray, who as you know, is the brains of the outfit. Thanks again to Sheldon & Greg at G&S Cruiser Parts for the 1HD-FT engine/Trans/TC unit. It's all in and running and we even drove around the neighborhood a bit. Lot's of wiring to the combination meter,
transmission control module/engine ecu to be mapped yet, probably a few more saturdays to finish of the electrical stuff. I hope the fuel economy is in the range you suggest.
BTW, my existing engine/tran/tc is up for grabs. It's got 71,000 miles(115,000 km) and has been fully dealer serviced since new.
Regards,
Jim
The thought of dropping a Hino Diesel engine in has long been floating about in my head... I even had a nearly new JO8C-TI sitting in my yard for year, 8.0L, 24 valve, ... shame it was too big for even the large 80 series engine bay... that and the 1200lbs it weighed were interesting obstacles to say the least. The the W04C-T is fairly close to a 13B-T, from what I can gather. It displaces 4.0L though. Bellhousings and such are vastly different, but some of the transmissions are 5 and 6 speed with some very low 1st gears... divorced t-case... anyone?
Me wants one...drool, drool, drool. I'd like to see a full writeup on this conversion please, including wiring etc. I for one have been waiting a long time for this but you beat me to it. Cheers
LX1HD-FT said:
Yep, Hi Rob
Regards,
Jim
Wow sounds great Jim, how many hours into the project and did everthing bolt up?
Did you have to put a fuel pump in line, pull fuel tank and remove factory fuel pump?
Thanks for the update
Someday the Canucks are going to be able to IMPORT HD80's.
That's what I'm waiting for.
Looking forward to some engine bay pics of that HD.
TB
LX450 Diesel Conversion
The conversion has taken 5 full Saturdays so far with several more to go. Also lots of electrical wiring diagram manual time as well. My conversion is complicated by the fact that the FT engine I have has an ECU controlled EGR system and also the electronically controlled 442 auto tranny. Ray, who is leading this expedition into the unknown, is also converting his LX450, after mine is completed, but he is installing a manual 5 speed tranny and his 1HD-T engine has no electronic controls, which should be considerably simpler.
Most everything bolts up fine. The rear driveshaft had to be lenghened. I had so much stuff like the radiator and shroud, air filter box, cruise control etc etc. come along with the engine so it was much easier because of that. Existing engine mounts worked but the transmission cross-member didn't.
The existing fuel pump was still in but not hooked up when we test rode the vehicle. There seemed to be some fuel starvation at top rpms so it may either have to be hooked up or removed, not sure on this issue yet.
When I originally replied to this thread I included a photo but I has evaporated. I attach a couple this time.
Regards, Jim
Looking real good, having the motor mounts as a guide for bolt in is a real good start.
Did you end up moving the tranny support brackets forward or back?
Did the drive shafts fit?
I was under the impression you would have to remove the fuel pump from the tank and run a 8 to 10 PSI electrical pump along the inner frame.
In retrospect I should never of sold the 1HD-T, should of kept it and put it in my wifes 80 series. Especially since I am sitting on the tranny for that particular motor.
Keep up the good work and keep us posted............
I had the correct tranny cross-member come along with all the other parts accompanying the engine/tran/tc. It bolts up to the same place on the frame but the tranny mount bolt holes are different because of the different tranny. The original one could probably be adapted to work.
As said before the rear driveshaft had to be lenghtened but the front was fine and the fuel pump situation will have to be assessed when the vehicle is test driven again, once all the electrical/electronic issues are resolved.
If the 442 tranny you have is a older hydraulically controled unit and not the electronic one it will be much simpler to use.
Nothing done the last couple of weekends but will have a go next weekend. I'm getting anxious to get some wheeling happening but expect it will be towards the middle to end of July before its ready.
rgds,
Jim
LX450 to 1HD-FT Diesel Conversion
I'm still wading through the electrical complexities of the diesel engine swap swamp.
Does anyone have a toasted 1FZ-FE engine wiring harness laying about? I'm looking for the 17 pin white plug that connects to its corresponding mate above the RH footwell near the Engine ECU inside the cabin. (see attached photo). With this plug I intend to leave the one inside the cabin intact and adapt the diesel engine harness to it.
Also, shamelessly, is a photo of the removed engine/tranny/tc which is low mileage, fully dealer serviced and up for sale.
Thanks,
Jim
Let me just say that you SUCK ( :cheers: ) and that that is turbo (diesel) cool.
Good luck.
TB :bounce:
Hltoppr said:
Jim, Please, Please, Please document your wiring and general conversion well for those of us who would like to follow in your footsteps!
-H-
Perhaps a full write up for the Tech Section of the site?
Very good ideas. Here here.
TB
You don't want that nasty gas engine cluttering up the garage do you?
I have a free disposal service where I just jot down your address and remove it off of the premises. ;p
This post can also be taken as how much do you want for the engine?
Hotlppr:
Regarding the diesel conversion technical write, I'm in an awkward position. At the onset of the project, the person (mechanic) that is doing the conversion for me, and I agreed that the information developed through this process would be his to disseminate.
This reason I agreed to this is that although he is charging me on an hourly basis for the mechanical and electrical work and travel time to my garage, he is not charging me for all his research time in order to acomplish this conversion. He, you see, is going to convert his LX450 as well, as soon as mine is finished. Because of this, he views his research time as an investment toward his conversion project. He probably has more than a week in referencing EWD manuals to develop a wiring conversion map and a score of trips to Lexus/Toyota parts desks to cross-reference different parts, all on his nickel.
So........., I expect that when our projects are complete, anybody that is going to undertake this conversion(non-trivial) would want to approach him.
Concerning names of suppliers, I found myself in the enviable position of getting most everything I needed from G&S Cruiser Parts (ie. all harnesses, relays, computers, radiators/shroud, air filter box etc etc.) The spaghetti in the forground of the attached photo is just a portion of the stuff that came with the engine. Because of this I only have go to the local autoparts stores to get miscellaneous things like fluids, electrical connectors and the like.
Lurker:
Please PM me to discuss the gas engine.
What ever happened to this project? Is it done yet? What are the results? Better than the 1FZE? Pro's and Con's?
Hello Rob and all,
Yes the vehicle is on the road since last weekend. There are a few non-critical things to finish off. The tach isn't functioning yet and I may have to get a new tach and a European electric wiring diagram manual to resolve the issue.
The tranny power and second gear start also aren't working and WILL need the manual for that as there is a potential to fry the ECU/TCM if done incorrectly. Air con should be hooked this week. Raymond has been busy at other things so it's taking a little longer than planned to completely finish but I'm daily driving with it now. The thing has torque up the wazoo and the fuel econmy appears great. I haven't put a full tank of fuel through yet but have chalked up 650 km (404 miles) and still have a quarter of a tank left. I'll track fuel economy for a bunch of fill-ups and report the mpg later.
The power of the FT engine is about on par with the FZE engine. I challenged Raymond in his '97 lx450 on a freeway. We both were traveling at 80 kph(50mph) and accelerated flat out to around 140kph(87mph). We stayed pretty much even with me just slightly ahead.
Once I install an inter-coooler and tweak the injection pump I should be considerably faster but for the fact that he's soon to be swapping in his 1HD-T/5 speed/inter-cooler combo so we will probably still be at a standoff:-)
'Tho not a cheap project I'm really happy with the results.
Regards,
Jim
