When I come to a stop, she dies. It only seams to happen at full operating temp. If I turn it off for 15 min or so, and start her up again, she runs fine untill reaching full oerating temp. She will die when coming to a stop or just pushing in the clutch running down the road. Also, every once in a while she'll miss and almost backfire.
It's desmogged according to the tech links here on mud about 3 years ago. At that time I did the following:
- Carb rebuild/dizzy recurve by Jim C
- All new vacuum lines
- New oem manifold gasket
- header
Recently I did a tune up, new plugs (gapped), new wires, new cap/rotor, set timing to 7* BTDC. I don't think I have an vacuum leak, sprayed wd-40 all over the place: vauum lines, arount manifold, around carb etc. I'm going to get a vacuum gauge to double check though. Is there anything else? I'm at a loss.
- header
