Did some cool *%$# tonight.
Pampa, Texas
Yea, I feel very accomplished right now. I installed my new 1/0 gauge battery cables from @Fourrunner and my new sPOD. The battery cables were pretty straight forward. They are huge! I can tell a huge difference in how fast the cruiser starts. It's like I put a new high torque starter in it.
The sPOD.... It was pricey, but worth every penny!! It couldn't be easier... Seriously. I bought a Tacoma kit because it came with a mounting bracket. I mounted it on the passenger side firewall above where the ac lines go in. I had to bend the mounting tabs to conform, but that was the only "custom" thing I had to do. I'm not a huge fan of wiring and relays, and fuses, and all that stuff that can go terribly wrong and burn my $#*% to the ground. I've only got my front light bar installed and wired at this point, but I've got ditch lights, another light bar up top, and a few other little goodies that I've got planned. All I have to do is hook up the power and ground to the sPOD and I'm done!
So, get the cables, and if you want peace of mind, get the sPOD. I know I'll sleep better tonight.
With as tough as these trucks are I'm surprised at the size of the battery cables and hope to do this upgrade soon. I upgraded the ground cable on my last 80 and it was a noticeable improvement.
It's still not entirely clear to me what the sPOD does. Combination battery tender/fuse box?
Me too, I hope it is a battery combiner and a really cool power take off point. Perhaps it is a set of relays that are prewired? You simply fit the switch and plug your accessory in and away you go?
regards
Dave
It's basically a box with relays/fuses in it.
I just looked on the website and I think you are spod on....sorry couldn't resist it., :). But for that money it surely it does more. I am thinking box with relays bolted under the bonnet and a low amperage all in one cable going to a switch box fitted in the cab?
Neat and easy way to wire something assuming everything is wired down the same side of the engine?
regards
Dave
regards
Dave
Yes, it's a pre-wired accessory point. All you have to worry about is connecting a power and ground to the battery, and everything else is covered. everything is just plug and play at that point, all your switches are pre-wired, numbered and everything has relays, circuit protection and is basically fool-proof.... I hate wiring, so this was very convenient for me.
I think it is a great idea if you are not 12v savvy or confident, never seen it before. I do my own wiring most of the time, so unless something that I need can be purchased cheaper than I can make it for, and of course the time factor, I would not have looked for it, nice one.
regards
Dave
